You are here: PSPad forum > Bug report / Hlášení chyb > 4.5.8 [2500] Code Explorer Bug
Posted by: syntech | Date: 2014-10-01 13:35 | IP: IP Logged
This is probably a new bug.
If I have a C function like
int blabla( int a, int b,
int c, int d,
int e, int f,
double (&abc)[MAX_ABC],
double (&def)[MAX_DEF] )
The code explorer shows:
Now, if I'm in the function somewhere and hit the button "show in document" (or so) from the code explorer, it highlightes the following line:
But the correct line should be:
int blabla( int a, int b, int c, int d, int e, int f, double (&abc)[MAX_ABC], double (&def)[MAX_DEF] )
I think the problem is, that there are round brackets used inside the round function brackets. PSPad should handle this correctly by counting the open/closed brackets and ignoring every bracket until the closing function bracket is found.
