You are here: PSPad forum > Bug report / Hlášení chyb > Re: Find/Replace dialogs fonts very small and window not vertically resizable
Posted by: Liuzzino | Date: 2014-09-16 07:52 | IP: IP Logged
Last version 4.5.9 (2503), It's better, but there are still problems using
win 7 125% system fonts.
Fonts are very small, and windows not vertically resizable.
Please go back to the old dialog boxes.
Regards
Posted by: pspad | Date: 2014-09-16 08:48 | IP: IP Logged
Can you send me screenshot please? You can send it to my support mail.
In previous version, windows wasn't resizable. New version allows you increase width of window if you need more chars in search/replace
Edited 1 time(s). Last edit at 2014-09-16 08:50 by pspad.
Posted by: Liuzzino | Date: 2014-09-16 09:12 | IP: IP Logged
OK, I'll send to you (support - pspad - com) a .pdf with some screenshots.
Regards
Edited 1 time(s). Last edit at 2014-09-21 18:52 by Stefan.
Posted by: DEROUSSEAUX | Date: 2015-01-21 14:56 | IP: IP Logged
Got the same problem with version 4.5.8 (2500):
The Find/Replace window is NOT resizeable vertically : dragging one corner diagonally will change the window width, but not its height.
This is annoying because obliges to scroll vertically inside the window to hit the "OK" button in order to activate the search or replace.
Thank you.
Posted by: pspad | Date: 2015-01-21 15:02 | IP: IP Logged
Go to PSPad developer forum and download latest 4.5.9 developer build. There was made many fixes for high DPI screen, include Find dialog.
Download and replace existing files with archive content
Posted by: DEROUSSEAUX | Date: 2015-01-30 16:27 | IP: IP Logged
Perfect ! Thanks a bunch.
