You are here: PSPad forum > Bug report / Hlášení chyb > Find / Replace dialog big with 125% system fonts
Posted by: Liuzzino | Date: 2014-09-05 08:28 | IP: IP Logged
I use 125% system fonts (win7) and the new resizable Find / Replace dialog
doesn't appears completely.
Greetings
Posted by: pspad | Date: 2014-09-05 08:39 | IP: IP Logged
Cana you send me screenshot please?
Posted by: Liuzzino | Date: 2014-09-05 09:05 | IP: IP Logged
I've already tried, but I don't know how to attach pictures inside forum messages.
Could you help me?
Posted by: pspad | Date: 2014-09-05 09:52 | IP: IP Logged
There are no attachments allowed.
But I hope I found a reason. In the next build it should be OK
Posted by: Liuzzino | Date: 2014-09-05 10:19 | IP: IP Logged
OK, anyway you can try to simulate the problem on your PC,
on Windows 7/8, open the Control Panel, then choose “Appearance and Personalization”, then “Display”, and finally select “Set custom text size (DPI)” (Windows 7) or “Custom sizing options” (Windows 8).
The drop-down box at the top lets you enter the desired DPI setting as a percentage value, where 100% equals 96 DPI. 125% equals 120 DPI. Up to Windows 7, the actual DPI value (“120 pixels per inch”) is shown next to the system font size. Windows 8 and later inexplicably drop the DPI value, so you have to calculate it yourself.
Check "Use Windows XP style DPI scaling"
When you have set 125%, launch PSPad, and you should see how looks the Find dialog window
Thanks for your quick response and support.
I'll wait for the next build
Regards
Posted by: Calvi | Date: 2014-10-03 22:50 | IP: IP Logged
I am getting the same problem on windows 8.1 and papas 4.5.9 2503
Resize horizontal is ok but vertical I cannot get rid of the scroll bars.
Posted by: pspad | Date: 2014-10-04 03:16 | IP: IP Logged
Wait for the next build pleae
