You are here: PSPad forum > Bug report / Hlášení chyb > Syntax highlight not working on big files
Posted by: TheRG | Date: 2014-09-03 12:57 | IP: IP Logged
The syntax highlighter seems to have troubles with source files that exceed a certain number of lines (between 10.000 and 20.000 lines). Nothing is highlighted when the file is too big.
Yes, I know it is a bad practice to have such a long source files, but there is no easy way to get rid of them.
I am using the latest version (4.5.8, build 2500).
Posted by: Stefan | Date: 2014-09-03 13:17 | IP: IP Logged
Please see if that will help you:
"Settings\Program Settings... " > [Direct edit] button
HLOnUpToSize=
MultiHLUpToSize=
More at forum.pspad.com
Posted by: pspad | Date: 2014-09-03 14:10 | IP: IP Logged
This will surely help. Tve value is maximal file size of bytes when highlighter is on. Set e.g. one milion bytes.
Posted by: TheRG | Date: 2014-09-03 19:03 | IP: IP Logged
Yes, it works nicely. Thank you both for your answers.
