You are here: PSPad forum > Bug report / Hlášení chyb > log parser issues
Posted by: pspad | Date: 2016-04-20 11:44 | IP: IP Logged
Did you set logparser to match your log? I don't think log parser is able to work with UNC without modification and if you switch it back to mapped drives, you need to set it up.
Log parser debuger will show for you parsed elements from log line
Edited 1 time(s). Last edit at 2016-04-20 11:44 by pspad.
Posted by: gwinkless | Date: 2016-04-20 11:57 | IP: IP Logged
gwinkless:If I switch the paths to use mapped drivenames and modify the compile output to match, double-clicking errors in the log seems to fail to work altogether :(
Scrub that. If I change the log parser to be %D%F:%L rather than %F:%L it works with mapped drivenames.
I'll do that, thanks for the hint.
Geoff
