You are here: PSPad forum > Bug report / Hlášení chyb > Re: Can't save Settings/special settings
Posted by: Manfred+49 | Date: 2014-02-20 17:26 | IP: IP Logged
I try to change the settings at
setting
/program settings
/special settings
Object Pascal Filter=Pascal files (*.pas;*.dpr;*.dpk;*.inc;*.dfm;*.xfm;*.pp)|*.pas;*.dpr;*.dpk;*.inc;*.dfm;*.xfm;*.pp
.pp for Free Pascal.
It keeps when I press OK on special settings.
If I leave Settings, the change is lost.
Where is this Table for the special settings saved.
Thank's
Manfred
Posted by: pspad | Date: 2014-02-20 18:51 | IP: IP Logged
Special settings same as the other settings are in PSPad.INI file.
I guess you install PSPad as portable into program files. No program has right to write there.
