You are here: PSPad forum > Bug report / Hlášení chyb > Re: ClipRun
Re: ClipRun
#1 ClipRun
Posted by: andthu | Date: 2013-12-04 17:03 | IP: IP Logged
I can't get this function to work in version 4.5.7.
It works beautifully in 4.5.4 and I use it all the time so I have returned to the older version.
Also, the behavior of Key mapping is strange - when I press Shift, the interactive window shows Alt..
Thanks for an otherwise great product.
#2 Re: ClipRun
Posted by: pspad | Date: 2013-12-04 17:45 | IP: IP Logged
It should be OK in the 4.5.8 build - available in the Developer forum
