You are here: PSPad forum > Bug report / Hlášení chyb > Mousewheel scrolling stops in large files with linebreak active
#1 Mousewheel scrolling stops in large files with linebreak active
Posted by: Georg | Date: 2013-02-28 09:18 | IP: IP Logged
there is a bug in version 4.5.8 (2453) and previous versions (did a test with 4.5.7 2449).
When i open a medium sized log file (~ 2.5 MB) with lines longer than the displayed width, go to a position near the end of the file and activate the linebreak option, i am not able to scroll forward with the mouse wheel (only backward).
If i disable the linebreak, i instantly can use the wheel as usual.
It appears as if the editor window denies to scroll further than ~ line 9050. The exact number depends also on the size of the font (curious).
#2 Re: Mousewheel scrolling stops in large files with linebreak active
Posted by: Georg | Date: 2013-03-06 11:46 | IP: IP Logged
I noticed, that also pasting text from clipboard into the document doesn't work.
Remember, that the things go wrong with activated line break only
#3 Re: Mousewheel scrolling stops in large files with linebreak active
Posted by: pspad | Date: 2013-05-11 08:59 | IP: IP Logged
Fixed in current developer build
