You are here: PSPad forum > Bug report / Hlášení chyb > Help file missing items
Posted by: glennman | Date: 2023-03-08 00:07 | IP: IP Logged
This is not a bug report, just a report on some items that seem to be missing in the otherwise excellent Help file.
There is no description of the Tool Panel.
There is no description of the Favorites (Links) list and how to use it.
The Search tab in the Help file does not seem to work.
Search for Bookmark finds nothing, but Bookmark is listed in the Index tab,
and appears in several Help pages.
Posted by: pspad | Date: 2023-03-09 07:47 | IP: IP Logged
PSPad is one man show with users support. I am hardly maintain application, help is updated continuously (if I find time for it) and published with main build.
Individual panels are described in the Wirking with PSPad. You are right, favorite panel is missing.
I just tested index and there are 2 entries in the Index tab - Bookmark and Bookmarks
Search tab should search in CHM file, but it doesn't - it's Microsoft HTML help functionality, not help itself functionality. I will try investigate, where is the problem.
Posted by: pspad | Date: 2023-03-09 08:11 | IP: IP Logged
Problem with search tab found. Even I have fresh installed OS with MS HTML Help workshop (CHM help compiler), problem is with registering MS help workshop libraries.
After reregistering compilers DLLs is necessary to recompile help files and search tab works again.
