You are here: PSPad forum > Bug report / Hlášení chyb > 5.0.7.745: automatic syntax hilight broken
#1 5.0.7.745: automatic syntax hilight broken
Posted by: brolx | Date: 2022-12-08 09:52 | IP: IP Logged
In 5.0.7.745 (32 bits), automatic syntax hilight based on file extension is broken.
It always uses C++ (unless we explicitely change it obviously).
#2 Re: 5.0.7.745: automatic syntax hilight broken
Posted by: rseibel | Date: 2022-12-08 10:14 | IP: IP Logged
See workaround from pspad (from dveloper forum PSPad unicode 5.0.7 (745) English):
As temporary workarround till next build you can disable "save file state" option in the program settings / Files and dirs
Edited 2 time(s). Last edit at 2022-12-08 10:16 by rseibel.
#3 Re: 5.0.7.745: automatic syntax hilight broken
Posted by: pspad | Date: 2022-12-08 10:27 | IP: IP Logged
I will publish new build this weekend
#4 Re: 5.0.7.745: automatic syntax hilight broken
Posted by: brolx | Date: 2022-12-08 11:44 | IP: IP Logged
Thanks alot
