You are here: PSPad forum > Bug report / Hlášení chyb > Access violation at address 0000000000412FCB
Posted by: PeVal | Date: 2022-01-21 07:35 | IP: IP Logged
Vážený pane,
měl jsem otevřené dva soubory php a při otevírání třetího mi to nahlásilo tuto chybu. Program ale nezatuhl a ani nespadl.
Mám PsPad 5.0.7 (715)
Exception description:
Access violation at address 0000000000412FCB in module 'PSPad.exe'. Read of address 00000000000000F7.
Exception address: 0000000000412FCB
Stack list, generated 21/01/2022 8:31:04
[00000000007F0131] JclDebug.TJclStackInfoList.Create (Line 5509, "JclDebug.pas" + 34) + $0
[00000000007EFC78] JclDebug.JclCreateStackList (Line 5351, "JclDebug.pas" + 1) + $3F
[00000000007EFBE6] JclDebug.DoExceptionStackTrace (Line 5292, "JclDebug.pas" + 20) + $15
[00000000007F2186] JclDebug.DoExceptNotify (Line 6741, "JclDebug.pas" + 7) + $0
[00000000007DF9B5] JclHookExcept.TNotifierItem.DoNotify (Line 272, "JclHookExcept.pas" + 5) + $11
[00000000007DFBFB] JclHookExcept.DoExceptNotify (Line 339, "JclHookExcept.pas" + 13) + $2B
[00000000007DFD55] JclHookExcept.HookedRaiseException (Line 381, "JclHookExcept.pas" + 14) + $0
[0000000000412013] System.@RaiseAtExcept + $103
[0000000000412078] System.@RaiseAgain + $38
[00000000004161AD] System.@FinalizeRecord + $45D
[000000000040FD21] System.TObject.CleanupInstance + $31
[000000000040F950] System.TObject.FreeInstance + $10
[0000000000410581] System.@ClassDestroy + $11
[000000000040FB64] System.TObject.Destroy + $24
[000000000040FB88] System.TObject.Free + $18
[000000000084919A] SynHighlighterMulti.TSynMultiSyn.ClearMarkers (Line 277, "SynHighlighterMulti.pas" + 2) + $16
[000000000084ACD9] SynHighlighterMulti.TSynMultiSyn.DoSetLine (Line 851, "SynHighlighterMulti.pas" + 3) + $0
[000000000088462B] SynEditHighlighter.TSynCustomHighlighter.SetLineExpandedAtWideGlyphs (Line 1220, "SynEditHighlighter.pas" + 5) + $0
[0000000000862F3B] SynEdit.PaintLines (Line 3281, "SynEdit.pas" + 163) + $0
[00000000008636AD] SynEdit.TCustomSynEdit.PaintTextLines (Line 3407, "SynEdit.pas" + 60) + $0
[000000000085FFE7] SynEdit.TCustomSynEdit.Paint (Line 2347, "SynEdit.pas" + 30) + $0
[0000000000797A4C] Vcl.Controls.TCustomControl.PaintWindow + $5C
[000000000078E389] Vcl.Controls.TWinControl.PaintHandler + $89
[00000000007954B2] Vcl.Controls.TWinControl.WMPrintClient + $82
[00000000004102D5] System.TObject.Dispatch + $45
[0000000000786CD0] Vcl.Controls.TControl.WndProc + $370
[000000000078E110] Vcl.Controls.TWinControl.WndProc + $980
[000000000086AD2B] SynEdit.TCustomSynEdit.WndProc (Line 5698, "SynEdit.pas" + 8) + $0
[00000000007867C2] Vcl.Controls.TControl.Perform + $32
[000000000078F18E] Vcl.Controls.TWinControl.WMPaint + $13E
[00000000007979DD] Vcl.Controls.TCustomControl.WMPaint + $1D
[000000000078D2AC] Vcl.Controls.TWinControl.MainWndProc + $2C
[000000000053F756] System.Classes.StdWndProc + $26
[00007FFC64BDE7E8] Unknown function at CallWindowProcW + $3F8
[00007FFC64BDE36C] Unknown function at DispatchMessageW + $39C
[00007FFC64BF0F93] Unknown function at SendMessageTimeoutW + $143
[00007FFC65D30BA4] KiUserCallbackDispatcher + $24
[00007FFC63B91464] NtUserCallHwndLock + $14
[0000000000792B10] Vcl.Controls.TWinControl.Update + $20
[000000000078525A] Vcl.Controls.TControl.Update + $1A
[00000000007853B8] Vcl.Controls.TControl.Repaint + $138
[0000000000B74BBD] uChildEdit.TfChildEdit.InternalLoadFromFile (Line 386, "uChildEdit.pas" + 13) + $0
[0000000000A9AED9] uChildParent.TfChildParent.LoadFromFile (Line 479, "uChildParent.pas" + 24) + $1E
[0000000000C60DF9] uMain.TfPSPad.OpenSynEditFile (Line 4406, "uMain.pas" + 32) + $18
[0000000000C760C5] uMain.TfPSPad.OpenFileByParams (Line 9544, "uMain.pas" + 178) + $0
[0000000000C76E8A] uMain.TfPSPad.WMGetCommand (Line 9740, "uMain.pas" + 29) + $D
[0000000000732AB1] Vcl.Forms.TCustomForm.WndProc + $9E1
[00007FFC64BF2B30] Unknown function at InitDManipHook + $4B0
[00007FFC63B91064] NtUserPeekMessage + $14
[00007FFC64BDA553] Unknown function at PeekMessageW + $1E3
[00007FFC64BDA4B3] PeekMessageW + $143
[0000000000741610] Vcl.Forms.TApplication.ProcessMessage + $30
[0000000000741788] Vcl.Forms.TApplication.HandleMessage + $18
[0000000000741BDF] Vcl.Forms.TApplication.Run + $EF
[0000000000CA8780] PSPad.PSPad (Line 120, "" + 57) + $0
[00007FFC64B17034] BaseThreadInitThunk + $14
[00007FFC65CE2651] RtlUserThreadStart + $21
Program : D:\ProgramyMoje\PsPad\PSPad.exe 5.0.7 (715)
System : Windows 10 Professional x64, Version: 10.0, Build: 4A62,
Processor: Intel, Intel(R) Core(TM) i3-8350K CPU @ 4.00GHz, 4000 MHz MMX
Display : 3840x2160 pixels, 32 bpp PPI: 144
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_M57533342"
Edited 1 time(s). Last edit at 2022-01-21 07:37 by PeVal.
Posted by: pspad | Date: 2022-01-21 09:24 | IP: IP Logged
Exception reports please to support mail
Update to current 32b version - you can simply replace your 64b with 32b version
