You are here: PSPad forum > Bug report / Hlášení chyb > error log - z jinak stabilniho editoru
Posted by: jadd | Date: 2021-11-21 03:53 | IP: IP Logged
Quote:Exception class: EAccessViolation
Exception address: 000000FF
Stack list, generated 21/11/2021 4:22:29
(FFFFF0FF) [000000FF]
[009DBA5D] uChildEdit.TfChildEdit.SynEditProcessCommand (Line 1167, "uChildEdit.pas" + 24) + $1A
[009DBBD5] uChildEdit.TfChildEdit.SynEditProcessCommand (Line 1208, "uChildEdit.pas" + 65) + $18
[007499E7] SynEdit.TCustomSynEdit.NotifyHookedCommandHandlers (Line 10316, "SynEdit.pas" + 9) + $20
[00742946] SynEdit.TCustomSynEdit.CommandProcessor (Line 7087, "SynEdit.pas" + 7) + $E
[0073F587] SynEdit.TCustomSynEdit.WMKillFocus (Line 5397, "SynEdit.pas" + 2) + $C
[006ACFE2] Vcl.Controls.TControl.WndProc + $2BE
[0068BACF] Vcl.Forms.TFormStyleHook.PaintNC + $12C3
[0068BAD5] Vcl.Forms.TFormStyleHook.PaintNC + $12C9
[0068BAEB] Vcl.Forms.TFormStyleHook.PaintNC + $12DF
[006AEAA6] Vcl.Controls.TControl.GetStyleName + $E
[00409E93] System.TObject.Dispatch + $13
[0062EAC6] Vcl.Themes.TStyleHook.WndProc + $14A
[0062ECBC] Vcl.Themes.TMouseTrackControlStyleHook.WndProc + $0
[00684F58] Vcl.Forms.TScrollingStyleHook.WndProc + $0
[0062E2E2] Vcl.Themes.TStyleHook.HandleMessage + $66
[0097D2FE] Vcl.Styles.TStyleEngine.HandleMessage + $9A
[0062B314] Vcl.Themes.TStyleManager.HandleMessage + $54
[006B0203] Vcl.Controls.TWinControl.DoHandleStyleMessage + $F
[006B1F37] Vcl.Controls.TWinControl.WndProc + $693
[0040A07E] System.@ClassDestroy + $2
[00543C5C] Vcl.Graphics.TCanvas.Destroy + $54
[00409A0C] System.TObject.Free + $8
[0062E7FA] Vcl.Themes.TStyleHook.WMNCPaint + $8A
[007418DA] SynEdit.TCustomSynEdit.WndProc (Line 6371, "SynEdit.pas" + 22) + $4
[006B1484] Vcl.Controls.TWinControl.MainWndProc + $2C
[004EAEE4] System.Classes.StdWndProc + $14
[00677865] Vcl.Forms.TCustomForm.SetWindowFocus + $4D
[00677990] Vcl.Forms.TCustomForm.SetActive + $90
[00678772] Vcl.Forms.TCustomForm.WMActivate + $3A
[0062E4CC] Vcl.Themes.TStyleHook.InvalidateNC + $20
[0068C519] Vcl.Forms.TFormStyleHook.WndProc + $31
[006884DB] Vcl.Forms.TFormStyleHook.IsStyleBorder + $1F
[00688517] Vcl.Forms.TFormStyleHook.HandleMessage + $23
[0040A444] System.TMonitor.Enter + $10
[00674FAF] Vcl.Forms.TCustomForm.WndProc + $6DB
[0040A62E] System.TMonitor.Exit + $1A
[00549E55] Vcl.Graphics.FreeMemoryContexts + $9D
[00679764] Vcl.Forms.TCustomForm.CMShowingChanged + $588
[006ACC1C] Vcl.Controls.TControl.Perform + $24
[006B1225] Vcl.Controls.TWinControl.UpdateShowing + $10D
[006B133A] Vcl.Controls.TWinControl.UpdateControlState + $BE
[006B432E] Vcl.Controls.TWinControl.CMVisibleChanged + $26
[0067A581] Vcl.Forms.TCustomForm.RequestAlign + $D
[006B49BA] Vcl.Controls.TWinControl.SetBounds + $CE
[0067B95B] Vcl.Forms.TScreen.GetMonitor + $B
[006AB64A] Vcl.Controls.TControl.SetVisible + $26
[00674729] Vcl.Forms.TCustomForm.SetVisible + $3D
[00679EFB] Vcl.Forms.TCustomForm.Show + $7
[0067A167] Vcl.Forms.TCustomForm.ShowModal + $183
[00AC2FB9] uException.TExceptionDialog.ShowException (Line 637, "uException.pas" + 18) + $7
[00AC289D] uException.TExceptionDialog.ExceptionHandler (Line 455, "uException.pas" + 7) + $4
[0067F2FE] Vcl.Forms.TApplication.HandleException + $5E
[006B14C1] Vcl.Controls.TWinControl.MainWndProc + $69
[0073F60C] SynEdit.TCustomSynEdit.WMSetFocus (Line 5421, "SynEdit.pas" + 1) + $C
[00671844] Vcl.Forms.SendFocusMessage + $10
[0067B9D4] Vcl.Forms.TScreen.UpdateLastActive + $20
[006777CA] Vcl.Forms.TCustomForm.SetFocusedControl + $296
[0040A91C] System.TMonitor.TryEnter + $28
[00674FC4] Vcl.Forms.TCustomForm.WndProc + $6F0
[00674ACB] Vcl.Forms.TCustomForm.WndProc + $1F7
[006892C7] Vcl.Forms.TFormStyleHook.MDIClientWndProc + $DB
[00675022] Vcl.Forms.Default + $3A
[0067524F] Vcl.Forms.TCustomForm.ClientWndProc + $1DB
[006B2042] Vcl.Controls.TWinControl.DefaultHandler + $E6
[00677376] Vcl.Forms.TCustomForm.DefaultHandler + $5A
[0062E130] Vcl.Themes.TStyleHook.CallDefaultProc + $20
[0068C2F3] Vcl.Forms.TFormStyleHook.WMWindowPosChanging + $1F
[006B508C] Vcl.Controls.TWinControl.CMInvalidate + $38
[0040D8B2] System.@FinalizeArray + $18A
[00677302] Vcl.Forms.TCustomForm.DestroyWindowHandle + $42
[006737EF] Vcl.Forms.TCustomForm.Destroy + $73
[00679910] Vcl.Forms.TCustomForm.CMRelease + $0
[00409D2A] System.@IsClass + $E
[00698258] Vcl.Menus.TMenuItem.SubItemChanged + $44
[00698209] Vcl.Menus.TMenuItem.MenuChanged + $39
[005E149A] Vcl.ComCtrls.TTabControlStyleHook.WndProc + $A
[006B4FF9] Vcl.Controls.TWinControl.Invalidate + $9
[00AA15F8] uMain.TfPSPad.mCloseItClick (Line 9631, "uMain.pas" + 7) + $8
[0069816A] Vcl.Menus.TMenuItem.Click + $AA
[0069992B] Vcl.Menus.TMenu.DispatchCommand + $13
[0067EE37] Vcl.Forms.TApplication.ProcessMessage + $F3
[0067EE7A] Vcl.Forms.TApplication.HandleMessage + $A
[0067F1B1] Vcl.Forms.TApplication.Run + $C9
[00AD63DD] PSPad.PSPad (Line 120, "" + 55) + $7
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 4A63,
Processor: Intel, Intel(R) Core(TM) i7-8750H CPU @ 2.20GHz, 2200 MHz MMX
Display : 2560x1440 pixels, 32 bpp PPI: 168
Skin : Windows10 SlateGray
Active Controls Hierarchy:
TPSSynEdit "FEditor1"
TfChildEdit "fEdit_V06171768"
Stalo se to pri otevrenem tabu s par radky, kam jsem do druheho tabu otevrel jeden html z lokalniho disku pres kontextovou nabidku Upravit v PSPadu. Po novem otevreni a overeni jestli se to stane zase jsem uz nebyl uspesny, takze to bylo nahodny.
Posted by: jadd | Date: 2021-11-21 10:36 | IP: IP Logged
Edit:Myslim ze se to stalo pri zavirani druheho (aktivniho) tabu. Jinak jak jsem psal uz se mi to pri nasledne simulaci nestalo. Jinak tohle se mi stalo poprve u teto verze a jinak ani drive kdy jsem pouzival 64-bit verze.
