You are here: PSPad forum > Bug report / Hlášení chyb > Access violation the four thousand six hundred seventeenth
#1 Access violation the four thousand six hundred seventeenth
Posted by: Extranjero | Date: 2021-01-09 18:04 | IP: IP Logged
Don't know, maybe the problem of the access violation only exists on the southern hemisphere, but here it's very easy to replicate:
--> close a file = access violation
--> close the program = access violation
--> editing/working for more than an hour = access violation
And yes, the problem is around for 15 years ore more, but now it became massive.
Removing the heavy sound it's producing, just would be a welcomed starting point, as access violation always occurrs twice, it wakes everyone up, even the deaf old dog, not even mentioning the bearded grandfather, walking around asking 'what happened? , what happened?'
So some mercy to us and a Happy New Year to all! smiling smiley
#2 Re: Access violation the four thousand six hundred seventeenth
Posted by: Extranjero | Date: 2021-01-21 08:26 | IP: IP Logged
Exception description:
Access violation at address in module 'ntdll.dll'. Write of address .
Exception class:
Exception address:
Stack list, generated 21/1/2021 05:25:15
(See forum.pspad.com
or forum.pspad.com)
INFO
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thank you very much!
Program : L:\aa-PORTABLEyLAUNCH\PROGS\ESENCIALES\PSPad\PSPad.exe 5.0.4 (539)
System : Windows 10 Professional x64, Version: 10.0, Build: 47BB,
Processor: Intel, Intel(R) Core(TM) i5-3330 CPU @ 3.00GHz, 3000 MHz MMX
Skin : Carbon
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-27 09:46 by Stefan.
#3 Re: Access violation the four thousand six hundred seventeenth
Posted by: pspad | Date: 2021-01-21 19:19 | IP: IP Logged
Please update to current version, build 543
#4 Re: Access violation the four thousand six hundred seventeenth
Posted by: Extranjero | Date: 2021-01-30 14:31 | IP: IP Logged
updated ...
not such a big difference, still happens twice closing one file.
Best regards
Exception class:
Exception address:
Stack list, generated 30/1/2021 11:26:47
Program : L:\aa-PORTABLEyLAUNCH\PROGS\ESENCIALES\PsPad\PSPad.exe 5.0.5 (547)
Skin : Carbon
TButton ""
TPanel ""
TfSettings "fSettings"
Edited 1 time(s). Last edit at 2021-04-27 09:47 by Stefan.
#5 Re: Access violation the four thousand six hundred seventeenth
Posted by: vbr | Date: 2021-02-01 18:52 | IP: IP Logged
just some more or less general guesses/suggestions -
does this error occur in a clean PSPad install - i.e. if you just unpack the current full version pspad504en.zip to some new empty folder (with read and write access) and then run PSPad.exe ?
If this would fix the problem, there might be some mismatch in the (possibly older) settings.
Is some specific file involved or does it crash with the mentioned exception on any file for you?
Do you use WSH-scripting? If it is activated, can you try to disable it temporarily and see, whether the crashes continue?
hth,
Edited 1 time(s). Last edit at 2021-02-01 18:53 by vbr.
#6 Re: Access violation the four thousand six hundred seventeenth
Posted by: Extranjero | Date: 2021-02-24 18:30 | IP: IP Logged
--> does this error occur in a clean PSPad install clean PSPad install portable version (read/write there), no older settings available
--> Is some specific file involved or does it crash
allways happened (started using PSPad in 2004 or 2005), files changed with time, but now it became massive (and happens always twice withe the same file closing it)
--> Do you use WSH-scripting
no and never used it
I noticed it happens frecuently when PSPad tries to add/quit a third file-tab-line, maybe that's a hint ...
#7 Re: Access violation the four thousand six hundred seventeenth
Posted by: pspad | Date: 2021-02-24 18:51 | IP: IP Logged
Please change skin from carbon to windows. Does it happen too?
