You are here: PSPad forum > Bug report / Hlášení chyb > 5.0 version copy and paste (doesn't work)
#1 5.0 version copy and paste (doesn't work)
Posted by: johntrot | Date: 2019-02-18 23:04 | IP: IP Logged
I have been using vwrsion 4... for the better part of 2 years.
after installing version 5.0..... I can no longer copy (Ctrl+C) or paste (Ctrl+V) from any file that is not open in pspad.
I can select text from anywhere on the web, but pspad refused to paste it in an open file in pspad.
Is there a setting somewhere I need to change or???
#2 Re: 5.0 version copy and paste (doesn't work)
Posted by: johntrot | Date: 2019-02-18 23:53 | IP: IP Logged
I cannot past from pspad to another file as well.
It appears that pspad does not recognize the files in question
#3 Re: 5.0 version copy and paste (doesn't work)
Posted by: pspad | Date: 2019-02-19 04:26 | IP: IP Logged
Hello.
What version? Current 5.0.1?
I have no report that is impossible copy/paste from naywhere. I didn't met it even I use PSPad every day myself.
PSPad disallow paste in case the file is open as read only. Can you edit your file?
#4 Re: 5.0 version copy and paste (doesn't work)
Posted by: johntrot | Date: 2019-02-19 17:23 | IP: IP Logged
I am using 5.0.1... the latest stable release. I simply downloaded the new version, installed with the exe file and now I cannot use the program at all.
I am going to delete everything and start over.
#5 Re: 5.0 version copy and paste (doesn't work)
Posted by: johntrot | Date: 2019-02-19 17:36 | IP: IP Logged
After removing pspad completely from my pc and re-installing (using the same pspad 501 setup exe file I used to upgrade with, the program is working.
There is most definitely something wrong with the installation when upgrading over the original files.
I am glad to have PsPad back working
