You are here: PSPad forum > Bug report / Hlášení chyb > tabsize troubles in secondary split window
#1 tabsize troubles in secondary split window
Posted by: matosimi | Date: 2016-03-06 20:14 | IP: IP Logged
I'm using my own syntax highlighter which has highlighter-specific tabsize set to 10.
When I use TAB in secondary split window, cursor moves only 2 characters in this window instead of 10 as expected.
Then when I try to type some letters after such TAB, these letters are inserted at correct position, BUT cursor position is incorrect.
...also text selection using mouse or shift+arrows is displayed incorrectly in secondary window.
It would be very nice if this will get fixed.
#2 Re: tabsize troubles in secondary split window
Posted by: pspad | Date: 2016-03-06 20:37 | IP: IP Logged
Can you confirm your bu in latest PSPad build 4.6.1? I't available in PSPad developer forum. There are some fixes related to real tabs already.
#3 Re: tabsize troubles in secondary split window
Posted by: matosimi | Date: 2016-03-12 14:37 | IP: IP Logged
Just tried new version and it really works good.
THANKS!
#4 Re: tabsize troubles in secondary split window
Posted by: pspad | Date: 2016-03-12 20:15 | IP: IP Logged
matosimi:
THANKS!
Thank you for confirmation
