You are here: PSPad forum > Bug report / Hlášení chyb > Open file in windows explorer
#1 Open file in windows explorer
Posted by: Macari | Date: 2014-10-29 09:59 | IP: IP Logged
Hey,
pspad is already open.
If I open a file per double click in windows explorer (windows 8), then pspad get focus and all file tabs get focus too. After all tabs get focused the file is open. I have everytime 10-50 files open and must wait seconds for finishing focus all tabs for each new open file. ;)
This not happen, if I open the file directly with pspad (open file...). Than the file is instant open.
This not happen, If I open the file with drag&drop from windows explorer to pspad. Than too, the file is instant open.
I have tested this with the actual beta version (2513) too.
#2 Re: Open file in windows explorer
Posted by: pspad | Date: 2014-10-29 16:28 | IP: IP Logged
Is PSpad already running when you open your files or you start it with this?
Which explorer integration do you use? Registry or DLL shell extension?
#3 Re: Open file in windows explorer
Posted by: Macari | Date: 2014-10-29 18:29 | IP: IP Logged
pspad is already running.
I use only standard double click on filename, not right click with a popup (I have no shell extension). I have not installed pspad, only unzipped in a folder.
#4 Re: Open file in windows explorer
Posted by: Macari | Date: 2014-11-13 20:49 | IP: IP Logged
2517 now working fine for me.
