You are here: PSPad forum > English discussion forum > Re: Tabs caption
Re: Tabs caption
Goto Page: Previous1 2
#11 Re: Tabs caption
Posted by: Alain75 | Date: 2026-09-04 23:18 | IP: IP Logged
As you can see in post #7, I don't use %n%.
The caption for tabs is "- %name% -" to enlarge it a little.
The goal is for my "big" sessions to have less tabs in line 1, more tabs in line 2 and so to more or less balance size of captions.
That is why it would be very great that the partern for tab caption could be applied to all tabs and not only to the first 9 ones.
#12 Re: Tabs caption
Posted by: Alain75 | Date: 2026-09-23 12:25 | IP: IP Logged
I made a last try on tab caption pattern :
— %d:nn is applied to all,
— %name% is of course applied to all tabs,
— but other characters (dashs in screenshot below) are not ?
#13 Re: Tabs caption
Posted by: pspad | Date: 2026-09-23 12:34 | IP: IP Logged
No I see what are you trying to do.
I can confirm, when I add mask e.g.:- %name% - %d:10 that additional chars like "-" are added to first 9 tabs only.
I will check it and fix it
#14 Re: Tabs caption
Posted by: pspad | Date: 2026-09-23 12:58 | IP: IP Logged
Fixed. Available in the next build (end of this week)
Future behavior:
%n%.. %name% - 1-9: with number.., rest: name only
%n% - %name% - 1-9: with number - name -, rest: - name -
- %name% - 1-9 same as the rest: - name -
it means %n% and chars followed without space will be stripped on tab >9
when something behind the %n% is followed by space, it stays
#15 Re: Tabs caption
Posted by: Alain75 | Date: 2026-09-24 10:32 | IP: IP Logged
Great, I will check as available !!!
Thanks a lot for your work
#16 Re: Tabs caption
Posted by: Alain75 | Date: 2026-09-25 16:18 | IP: IP Logged
Awesome : version 5.5.3 (873) fixes the bug !
Thanks so much, Jan !!! smiling smileysmiling smileysmiling smiley
