You are here: PSPad forum > English discussion forum > Run Macro: Keyboard Shortcut Is Not Saved
#1 Run Macro: Keyboard Shortcut Is Not Saved
Posted by: jtrumpfheller | Date: 2026-08-15 16:53 | IP: IP Logged
Okay, since the last update (5.5.2 (851)), macro keyboard shortcut assignment no longer works correctly.
There is a macro that I saved as MyMacro.pme in C:\Users\MyUsername\AppData\Roaming\PSpad\Macro. The PSPad.INI file is located at C:\Users\MyUsername\AppData\Roaming\PSpad. It contains the following lines:
[Macro]
Macro1=MyMacro
Macro2=Play Macro 2
Macro3=Play Macro 3
Macro4=Play Macro 4
When I open the Macro Manager, I see “MyMacro” in the macro list. However, it doesn’t have a keyboard shortcut assigned to it. I set it up again: “MyMacro” should be executed with F5. As long as PSPad is running, the shortcut works. After closing PSPad and restarting it, the shortcut is gone again. Previously, I was able to save the shortcut permanently.
#2 Re: Run Macro: Keyboard Shortcut Is Not Saved
Posted by: jtrumpfheller | Date: 2026-09-27 14:12 | IP: IP Logged
Is there no other one have the same problem? Or anyone knows how to fix it?
#3 Re: Run Macro: Keyboard Shortcut Is Not Saved
Posted by: pspad | Date: 2026-09-28 08:34 | IP: IP Logged
I have no problem with it, but I will take a look.
Please look in the script folder if you don't assign F5 to any script.
Another place is code templates. You can see shortcuts in the menu settings / code clips shortcuts
What highlighter do you use?
#4 Re: Run Macro: Keyboard Shortcut Is Not Saved
Posted by: pspad | Date: 2026-09-29 11:39 | IP: IP Logged
Problem was with localizations. Fix will be available in the next build
#5 Re: Run Macro: Keyboard Shortcut Is Not Saved
Posted by: jtrumpfheller | Date: 2026-10-23 16:31 | IP: IP Logged
I use HTML multihighlighter
#6 Re: Run Macro: Keyboard Shortcut Is Not Saved
Thanks, I appreciate it
