You are here: PSPad forum > English discussion forum > Re: Search in project with suare brackers, open empy tabs!
Posted by: Jonny | Date: 2026-08-01 22:56 | IP: IP Logged
Hi Pspad,
I tried the latest version of the program, Developer version 5.5.2 (845).
Unfortunately, the problem remains: if I perform a search in a pspad project where I have directories and/or files containing square brackets, pspad finds the results correctly, but if I click to open one of the files indicated in the results screen (with a path containing square brackets), pspad opens an untitled, empty tab.
Posted by: pspad | Date: 2026-08-02 01:43 | IP: IP Logged
Send mi any your ppr (project) file into support mail please
Posted by: pspad | Date: 2026-08-06 07:11 | IP: IP Logged
I found another problem what causes not open your file. I hope this time it is already fixed. Wait for the next build.
Posted by: Jonny | Date: 2026-08-06 22:42 | IP: IP Logged
Thank you so much for your time.
I like and use very much your app. I hope this problem is solved because I haven't been able to use the new versions from 5.0.6 (589)
If it helps, I'll also send you some *.ppr files that I use, here is a link to download some of the bigger *.ppr (the link will expire in 7 days):
limewire.com
Posted by: pspad | Date: 2026-08-07 04:16 | IP: IP Logged
The problem with search should be fixed in current full version
Posted by: Jonny | Date: 2026-08-15 08:44 | IP: IP Logged
Thank you so much, PsPad, for your patience.
The program now works also for searching within paths with square brackets.
And I can start using all the other features of the new version.
