You are here: PSPad forum > English discussion forum > Re: New Extensions
Re: New Extensions
#1 New Extensions
Posted by: andrew | Date: 2026-06-19 10:33 | IP: IP Logged
Hi, I am using PSPad to complement VS Code.
These are the extensions which I think should be added into PSPad - Haskell, Golang, Scala, R, Julia, and Oberon+.
Just for your thoughts.
#2 Re: New Extensions
Posted by: pspad | Date: 2026-06-19 11:20 | IP: IP Logged
Extension = Syntax?
User highlighter (syntax definition) for Haskell, R, Oberon exists. Assign it.
Golang, Julia and Scala don't exists, but PSPad allows you add new syntax highlight.
All you need is list of keywords
#3 Re: New Extensions
Posted by: ly47 | Date: 2026-09-22 07:49 | IP: IP Logged
Hi
These are the extensions for AutoIt3 (*.au3) and for Fasm(assembly)(*.asm) ?
Thanks
ly
#4 Re: New Extensions
Posted by: pspad | Date: 2026-09-22 08:16 | IP: IP Logged
I think there is some misunderstanding in terminology.
What does your "extension" do in VS Code?
#5 Re: New Extensions
Posted by: ly47 | Date: 2026-09-22 10:20 | IP: IP Logged
Hi
I mean User highlighter for file extension like *.asm for Fasm compiler and *.au3 for AutoIt(script program) files.
thanks
(sorry for my bad English)
ly
#6 Re: New Extensions
Posted by: pspad | Date: 2026-09-22 11:04 | IP: IP Logged
Menu settings / Highlighter settings
on the list bottom is 10 free slots for user hihglighters
Click on the free slot and on the second tab select any user highlighter deffinition to assign it, e.g. Auto It.
It's all.
PSPad contains tool where you can create new user highlighter or modify existing - menu settings / User highlighter
#7 Re: New Extensions
Posted by: ly47 | Date: 2026-09-22 12:30 | IP: IP Logged
HI
Thanks
ly
