You are here: PSPad forum > English discussion forum > Re: async function is not listed in code explorer
#1 async function is not listed in code explorer
Posted by: Alain75 | Date: 2025-11-30 17:03 | IP: IP Logged
It is not a regression from version 5.5.1 or any lower one. But PSPad doesn't recognize async functions of Javascript and doesn't include them in code explorer.
Syntax is :
async function NameOfFunction(ListOfOptionalParameters) ...
Thanks a lot if you can fix it !!!
#2 Re: async function is not listed in code explorer
Posted by: pspad | Date: 2025-12-10 08:56 | IP: IP Logged
added async to code highlighter
added async to code parser
#3 Re: async function is not listed in code explorer
Posted by: Alain75 | Date: 2026-01-07 16:14 | IP: IP Logged
Thanks ! smiling smiley
#4 Re: async function is not listed in code explorer
Posted by: Alain75 | Date: 2026-01-07 16:24 | IP: IP Logged
Hi jan,
can you confirm when you have time that the function will so appear in the code explorer window (CTRL+E) ?
#5 Re: async function is not listed in code explorer
Posted by: pspad | Date: 2026-01-07 19:01 | IP: IP Logged
I must publish new build
