You are here: PSPad forum > English discussion forum > async function is not listed in code explorer
Posted by: Alain75 | Date: 2025-11-30 18:03 | IP: IP Logged
It is not a regression from version 5.5.1 or any lower one. But PSPad doesn't recognize async functions of Javascript and doesn't include them in code explorer.
Syntax is :
async function NameOfFunction(ListOfOptionalParameters) ...
Thanks a lot if you can fix it !!!
Posted by: pspad | Date: 2025-12-10 09:56 | IP: IP Logged
added async to code highlighter
added async to code parser
Posted by: Alain75 | Date: 2026-01-07 17:14 | IP: IP Logged
Thanks !
Posted by: Alain75 | Date: 2026-01-07 17:24 | IP: IP Logged
Hi jan,
can you confirm when you have time that the function will so appear in the code explorer window (CTRL+E) ?
Posted by: pspad | Date: 2026-01-07 20:01 | IP: IP Logged
I must publish new build
