You are here: PSPad forum > English discussion forum > Another format of block comments
#1 Another format of block comments
Posted by: LigH | Date: 2025-08-17 21:59 | IP: IP Logged
Hello there! winking smiley
I noticed that the syntax highlighter file for Avisynth is a little outdated now. Not only the set of core keywords, also the structure syntax got developed further in AviSynth+. So I tried to add some elements to the highlighter INI file.
One piece is that it supports block comments, not only EOL comments '#' like in PHP. One supported syntax is C-like '/* */' but there is also an alternative style to allow nesting which lacks support in PSPad because it would need the implementation of a new comment style class: Asterisks in brackets '[* *]'
The full AviSynth grammar / Comments
