You are here: PSPad forum > English discussion forum > Re: Add/Remove comment in 5.5.1 (825) not working
Posted by: Joel | Date: 2025-08-16 19:40 | IP: IP Logged
I finally upgraded from 5.0.4, but Ctrl+Shift+A does nothing. The menu Format > Add/Remove comment also does not work. Is this a known bug, or do I have to change a setting?
Posted by: pspad | Date: 2025-08-17 02:48 | IP: IP Logged
Add/Ten ve comment works for line commenst for selected lines. Internal highlighters comments are defined, for user defined highlighters there is a field to define comment
Posted by: Joel | Date: 2025-08-19 18:35 | IP: IP Logged
Sorry if I am misunderstanding. When I select a line, and use Ctrl+Shift+A, or, if I use menu > Format > Add/Remove Comment, the selected line does not get commented.
I looked at User Highlighter settings but don't understand how to configure it.
Posted by: pspad | Date: 2025-08-19 19:23 | IP: IP Logged
What file type (highlighter) are we talking about?
