You are here: PSPad forum > English discussion forum > Re: How to disable sound on exit/quit PSPad?
#1 How to disable sound on exit/quit PSPad?
Posted by: dapspuser | Date: 2025-08-13 07:13 | IP: IP Logged
Is there a way to disable sound on exit?
Edited 1 time(s). Last edit at 2025-08-13 07:14 by dapspuser.
#2 Re: How to disable sound on exit/quit PSPad?
Posted by: pspad | Date: 2025-08-13 07:31 | IP: IP Logged
Use 32b version. I guess sound is caused by error when exiting 64b version
#3 Re: How to disable sound on exit/quit PSPad?
Posted by: dapspuser | Date: 2025-08-17 05:53 | IP: IP Logged
Thanks for the hint.
Is this an error on PSPad or in Windows?
#4 Re: How to disable sound on exit/quit PSPad?
Posted by: pspad | Date: 2025-08-17 09:54 | IP: IP Logged
64b version is still marked as experimental. On some systems it causes some problems
