You are here: PSPad forum > English discussion forum > Re: crash while closing tabs - messed up text file
Posted by: matosimi | Date: 2025-06-30 18:48 | IP: IP Logged
Hey,
I'm experiencing this issue for a long time. Currently running 5.5.1 (825).
I'm getting access violation error when I'm closing tabs, like when I have 8+ tabs opened and closing them 1 by 1.
When this happens, usually one source file gets corrupted. Some "y" character with 2 dots above 0x79 appears at the beginning of a single line followed by 0x00.
This messes up my code parser which ignores the rest of the line after 0x00 which results in skipped instruction. When I put single line comment character prior the "y", the characters after 0x00 are not displayed in comment color (so apparently the 0x00 messes up something highlighter as well).
Is this a known issue?
It does not happen very often, but when it does it is causing unexpected code behavior without immediate reason.
Posted by: vbr | Date: 2025-06-30 20:47 | IP: IP Logged
matosimi:Hey,I'm experiencing this issue for a long time. Currently running 5.5.1 (825).
This messes up my code parser which ignores the rest of the line after 0x00 which results in skipped instruction. When I put single line comment character prior the "y", the characters after 0x00 are not displayed in comment color (so apparently the 0x00 messes up something highlighter as well).Is this a known issue?
it seems the problems with randomly inserted "ÿ" characters etc.
forum.pspad.com
was also seen a few times in connection with closing the tabs and access violations
forum.pspad.com
Unfortunately, the roots of this problems couldn't be identified more precisely sofar.
