You are here: PSPad forum > English discussion forum > Re: PowerShell here-string recognition
#1 PowerShell here-string recognition
Posted by: clanman | Date: 2025-05-28 11:43 | IP: IP Logged
In PowerShell there is such a thing as a here-string (see half way down learn.microsoft.com) for hear-string information.
what I am trying to do is tell PSPad @' and @" are the beginning of a here-string and an accompanying '@ or "@ characters. Everything within the matching characters should be treated as a string.
#2 Re: PowerShell here-string recognition
Posted by: pspad | Date: 2025-05-28 12:17 | IP: IP Logged
PowerShell highlighter is hard coded. It must be modified to be able work with this kind of strings.
Can you send me some code examples into support mail?
#3 Re: PowerShell here-string recognition
Posted by: pspad | Date: 2025-07-10 10:27 | IP: IP Logged
PWS here-string support was added. Will be available in the next build.
#4 Re: PowerShell here-string recognition
Posted by: pspad | Date: 2025-07-11 07:41 | IP: IP Logged
New build in developer forum has been already released
#5 Re: PowerShell here-string recognition
Posted by: hajexav908 | Date: 2025-08-09 08:54 | IP: IP Logged
To configure PSPad to recognize PowerShell here-strings (@' ... '@ and @" ... "@) as strings, you’ll want to define these delimiters properly in its syntax highlighting settings. PSPad allows you to customize syntax highlighting by specifying string delimiters.
Here’s what you need to do:
Open PSPad.
Go to Settings > Configure User Defined Languages.
Select the PowerShell language or create a new user-defined language for PowerShell.
Find the Strings or Quotes section.
Add the following pairs as string delimiters:
Start: @' End: '@
Start: @" End: "@
This tells PSPad that everything between those start and end markers should be treated as a string, just like regular single or double-quoted strings.
Note:
Make sure to include the @ symbol as part of the delimiter to match PowerShell here-string syntax exactly.
If PSPad does not support multi-character delimiters directly, you might need to adjust or check if your version supports it or if you can define a keyword-based rule.
If you want me to, I can help create a sample snippet or a User Defined Language XML for PSPad to handle here-strings properly. Would you like that?
#6 Re: PowerShell here-string recognition
Posted by: pspad | Date: 2025-08-09 10:54 | IP: IP Logged
Maybe you mistook editor. PSPad doesnt use xml language definition.
Multiline syntax is already supported in the last build for PowerShell
