You are here: PSPad forum > English discussion forum > BUG] endless replace
#1 BUG] endless replace
Posted by: nspp | Date: 2025-05-19 03:46 | IP: IP Logged
I want to add 2 empty lines to a file before each line starting with #---
I used the Search & Replace :
Search: ^#---
Replace: \n\n#---
Option : "Regular expression",
Direction: "Entire Scope",
Scope : "Global"
If i process, the replacement goes into an endless loop.
As i add new lines, instead searching the next expression after the replaced text, it seems that the search stay in same line as the replaced text.
This cause an infinite loop.
If you tick Prompt user you can see the issue.
#2 Re: BUG] endless replace
Posted by: pspad | Date: 2025-05-19 04:29 | IP: IP Logged
If you want to create new line with replace, start on the end with backward direction, not global.
I know it's a bug, this is a workaround
#3 Re: BUG] endless replace
Posted by: nspp | Date: 2025-05-20 05:21 | IP: IP Logged
Many thanks for the tip.
I also succeeded adding a tab in the replaced string to alter startup matching.
