You are here: PSPad forum > English discussion forum > Re: How to write English and Cyrillic in the same file?
Posted by: abrogard | Date: 2025-04-21 22:14 | IP: IP Logged
I find I cannot add cyrillic text to my english text files.
If they were encoded in utf-8 I'm told I could. So I try to change the encoding but clicking on the menu choice does nothing.
how can i deal with this problem?
Posted by: pspad | Date: 2025-04-22 04:32 | IP: IP Logged
There is no problem to use together cyrilic, latin, japanese, ...
Necessary conditions: use any unicode font which supports all characters
Switch keyboard to cyrilic or paste cyrilic text
Posted by: Freeman | Date: 2025-06-29 16:56 | IP: IP Logged
Isn't this issue?
Posted by: wettbonusfinder | Date: 2025-12-27 13:11 | IP: IP Logged
You can mix English and Cyrillic in the same PSPad file without any real issues. Just use a Unicode font that supports both alphabets, switch your keyboard to Cyrillic (or paste the text), and make sure the file is saved in UTF-8 or another Unicode encoding. After that, everything should work normally.
