You are here: PSPad forum > English discussion forum > Re: PsPad 5.5.1 x64
Re: PsPad 5.5.1 x64
#1 PsPad 5.5.1 x64
Posted by: target232 | Date: 2025-03-12 15:49 | IP: IP Logged
When I open my *.aspx in PsPad 5.5.1 x64 it opens it as Encoding 1252 even if
I set file as UTF-8 with no BOM
encoding 1250 it also detects as 1252 ?
It look like this new PsPad could not detect correctly encoding ?
this is breaking my source code sad smiley
please help smiling smiley
#2 Re: PsPad 5.5.1 x64
Posted by: target232 | Date: 2025-03-12 15:59 | IP: IP Logged
My friends also noticed this, so if you are not paying attention to encoding you can break your file with wrong encoding which is automatically set to 1252, so far only thing that works is to set file to UTF-8 With BOM.
Only files with BOM will be correctly detected
#3 Re: PsPad 5.5.1 x64
Posted by: pspad | Date: 2025-03-12 16:08 | IP: IP Logged
If file doesn't contains any special chars or accented chars, the file content is same in utf-8 no BOM and CP1250 encoding. PSPad has no chance detect it.
Edited 1 time(s). Last edit at 2025-03-12 16:09 by pspad.
#4 Re: PsPad 5.5.1 x64
Posted by: target232 | Date: 2025-03-13 08:18 | IP: IP Logged
Till version 5.0.7 this worked fine, it started with this 5.5.1 version.
#5 Re: PsPad 5.5.1 x64
Posted by: pspad | Date: 2025-03-13 09:18 | IP: IP Logged
There was no change in code page detection between 5.0.7 and 5.5.1
Ensure, you have enabled Save file state option in the program settings / Files
It will remember code page for your previously open files too.
#6 Re: PsPad 5.5.1 x64
Posted by: target232 | Date: 2025-03-13 10:11 | IP: IP Logged
thank you
#7 Re: PsPad 5.5.1 x64
Posted by: MIB | Date: 2026-03-04 15:36 | IP: IP Logged
I don't know if this thread still is watched, but I have just the same effect.
I have a file from a web-page, utf-8 no bom coded, and it contains a few german special characters "Ü" as code C39C and ps-pad always opens it with the ansi codepage 1252. I set default codepage to utf-8 no bom in the ps-pad program settings -> files and directories, but ps-pad still opens the file with the ansi codepage and the word Überschuss always comes as Überschuss.
Michael
