You are here: PSPad forum > English discussion forum > 404 Not found, Nenalezeno
#1 404 Not found, Nenalezeno
Posted by: MASH73 | Date: 2025-02-28 09:27 | IP: IP Logged
using PSPad 5.5.1 (825)
This URL (https://www.pspad.com/files/pspad/pspad5_ftp_ssl.zip) leads to a 404 !
ConnectFTP > New Connection > Download SSL/TLS support
#2 Re: 404 Not found, Nenalezeno
Posted by: pspad | Date: 2025-02-28 09:39 | IP: IP Logged
OpenSSL libraries are part of PSpad, it means it should be in the PSPad folder already.
But you are right, the link should work - I fixed it.
