You are here: PSPad forum > English discussion forum > Portable has virus
Portable has virus
#1 Portable has virus
Posted by: Mark10 | Date: 2025-02-08 23:43 | IP: IP Logged
The portable version has viruses, according to virustotal.com
www.virustotal.com
Edited 1 time(s). Last edit at 2025-02-08 23:44 by Mark10.
#2 Re: Portable has virus
Posted by: pspad | Date: 2025-02-09 10:03 | IP: IP Logged
ClamAV marks pspad with false positive near regularly. Its neverending story. I have to report it and they remove false positive report.
If any serious engine doesn't mark application as dangerousbor if there is only one or two marks, you can be sure it's false positive.
#3 Re: Portable has virus
Posted by: pspad | Date: 2025-02-09 10:10 | IP: IP Logged
False positive report has been sent to both companies
#4 Re: Portable has virus
Posted by: Libia_Casper | Date: 2026-06-26 14:09 | IP: IP Logged
I'd also try testing it with a brand-new profile or default settings just to rule out an old configuration causing the issue. It's a quick check and can save a lot of time troubleshooting.
