You are here: PSPad forum > English discussion forum > Set character set when opening a file
Posted by: idefix2 | Date: 2025-01-04 14:22 | IP: IP Logged
I have to work in two different environments, one is windows, the other is msdos (vdos).
It would be very helpful if there was a way to add info about the character set of a file when opening pspad with a filename in the command line. Currently, I open a file, change the character set and reload the file. That is somewhat cumbersome...
Posted by: pspad | Date: 2025-01-06 09:14 | IP: IP Logged
It's not implemented now, but I will try to do it.
Posted by: idefix2 | Date: 2025-01-11 12:57 | IP: IP Logged
That would be great, thank you!
