You are here: PSPad forum > English discussion forum > Is it wrapping line working as usual ?
#1 Is it wrapping line working as usual ?
Posted by: giovanni | Date: 2024-12-05 15:42 | IP: IP Logged
I updated to last version and I got a issue with wrapping line function.
I set to 80 chars the vertical line of text end and then using the icon or Ctrl+W it don't align text as usual. Very strange. First time it happens.
Did I miss something ?
#2 Re: Is it wrapping line working as usual ?
Posted by: pspad | Date: 2024-12-05 16:39 | IP: IP Logged
The wrapping depends of the setting
Program settings / Editor 1
uncheck Wrap line (soft) with right edge
#3 Re: Is it wrapping line working as usual ?
Posted by: giovanni | Date: 2024-12-07 12:00 | IP: IP Logged
OK Thanks
