You are here: PSPad forum > English discussion forum > Manually edit PSPad.ini to reorder the panels
Posted by: dewcansam | Date: 2024-11-12 22:51 | IP: IP Logged
Is there a way to manually edit PSPad.ini to reorder the panels ?
I'm using wine on Mint 21 (and it works great even better than other win editors thanks). If you drag the FTP panel off, it does not appear as a sub window like all the other panels. It breaks off into it's own window. The only way to fix it is to manually edit PSPad.ini and to set FTPPanel=1. But once I do that it totally resets the location of all the other panels.
So is there a way to reorder the panels in PSPad.ini ?
p.s. When you do pull the FTP panel off it sets FTPPanel=0 hence the need to edit the config file and re-set FTP to 1.
edit: After opening PSpad in Windows with the panels being in the order that I had set. Now they are returning to the default.
So the real question should be CAN you reorder the panels and keep them that way ?
Edited 2 time(s). Last edit at 2024-11-12 22:56 by dewcansam.
Posted by: pspad | Date: 2024-11-13 05:48 | IP: IP Logged
No, there is no way to reorder panels. You can only switch off some panels.
For manually edit config, use program settings / Direct edit button
Posted by: dewcansam | Date: 2024-11-15 05:31 | IP: IP Logged
Thanks
