You are here: PSPad forum > English discussion forum > what font in code explorer window
#1 what font in code explorer window
Posted by: mdjones | Date: 2024-10-26 18:08 | IP: IP Logged
Hello, I like the font used in the code explorer window, it is small, clear, crisp, easy to read while displaying a lot of text, I want to use that same font in the editor window.
But I cannot seem to find anything in the Menu:Format:Font that matches.
Please tell me what font is used in the code explorer window, and how to select that as the editor font.
Thanks.
#2 Re: what font in code explorer window
Posted by: pspad | Date: 2024-10-26 18:51 | IP: IP Logged
Editor window uses nonproportional fonts only to align text into column
#3 Re: what font in code explorer window
Posted by: mdjones | Date: 2024-10-28 20:04 | IP: IP Logged
Oh yes, thanks, hadn't thought to notice that aspect of the font.
I am still curious what font it is though (in the code explorer window), I would use it elsewhere.
#4 Re: what font in code explorer window
Posted by: pspad | Date: 2024-10-29 08:18 | IP: IP Logged
I let there MS default font. It depends of your system version.
MS use substitution MS Shell DLG font
It can be Tahoma
#5 Re: what font in code explorer window
Posted by: mdjones | Date: 2024-10-29 21:25 | IP: IP Logged
Thanks, that is actually very helpful, I appreciate this.
