You are here: PSPad forum > English discussion forum > Re: Please help! Configuration problem.
Posted by: idefix2 | Date: 2024-08-24 02:13 | IP: IP Logged
Hi!
I have made some changes to my PsPad configuration, and I don't know what mistake I made.
Until now, when I entered the command "PsPad abc.txt" and the file abc.txt was already open in PsPad, the program just activated the already runnning PsPad window and switched to the tab with this filename. Now, a new instance of Pspad starts and the same file is open in two windows.
How can I change the configuration of PsPad back so that it returns to the old behaviour?
Posted by: pspad | Date: 2024-08-24 03:44 | IP: IP Logged
Ehat foes it means "it's open in 2 windows"? Do you mean 2 pspads are open?
In the program settings / system enable only one program instance
Posted by: idefix2 | Date: 2024-08-24 22:22 | IP: IP Logged
Yes, thank you, that was the problem. I unintenionally have enabled running multiple copies of PsPad in the configuration. Resetting this was enough to make Pspad work as it has always done.
