You are here: PSPad forum > English discussion forum > Re: PsPad text files have a padlock?
#1 PsPad text files have a padlock?
Posted by: EL34 | Date: 2024-08-08 16:36 | IP: IP Logged
This just started happening.
Not sure why, but newly saved PsPad text files have a padlock on the icon?
I do not have Bitlocker turned on in Windows 11, but I did encrypt a text file the other day using 7 zip.
I did not encrypt the text files in question here.
I looked in PsPad setting to see on some sort of encryption was turned on but don't see anything
Why is this happening?
Thanks
Edited 1 time(s). Last edit at 2024-08-08 16:38 by EL34.
#2 Re: PsPad text files have a padlock?
Posted by: pspad | Date: 2024-08-08 18:05 | IP: IP Logged
Is poddible to provide screenshot?
PSPad has no buil in file encryption
Are you sure you doesn't set encryption attribute on folder?
#3 Re: PsPad text files have a padlock?
Posted by: EL34 | Date: 2024-08-09 12:24 | IP: IP Logged
I figured it out
It was only happening to files on my desktop which is where I had originally created a password protected file in 7 zip
If you right click on the folder and
choose properties - advanced - then uncheck Encrypt contents to secure data
Not sure why Windows 11 checked this box because I have never encrypted files
Anywho, problem is not a PSPad issue, it is a Windows issue
