You are here: PSPad forum > English discussion forum > command line argument to jump to end of file
Posted by: dano | Date: 2024-06-18 06:49 | IP: IP Logged
I see that using /nnn on the command line will open a file and jump to that line (nnn) but I want to go to the end of the file.
I did /1000000 and that works but I'm curious if there is an official way to jump to the end of the file when opening it.
Edited 1 time(s). Last edit at 2024-06-18 06:50 by dano.
Posted by: pspad | Date: 2024-06-18 07:32 | IP: IP Logged
No, there isn't command line parameter to jump end of the file.
Your solution is fine, it will jump to last available line
