You are here: PSPad forum > English discussion forum > Bug in replacing string
#1 Bug in replacing string
Posted by: garbuya | Date: 2024-05-30 18:13 | IP: IP Logged
I have a string where all fields are delimited by |
a|b|c|||d|||e||||f|
I would like to split it into the separate lines
When I try to do a regexp_replace "|" with "|\n", the application hangs and after ~20 sec I'm getting infinite messages "Access violation error at F55E4C", so I cannot even close app and have to kill it in Task manager
Edited 1 time(s). Last edit at 2024-05-30 18:18 by garbuya.
#2 Re: Bug in replacing string
Posted by: pspad | Date: 2024-05-31 06:09 | IP: IP Logged
Start on the end of file with backward direction
#3 Re: Bug in replacing string
Posted by: garbuya | Date: 2024-05-31 16:25 | IP: IP Logged
It does not work
ab|cd||||ef|||ghi|j|
with backward replace "|" by "|\n" returns
a|
b|
c|
d|
e|
f|
g|
h|
i|
j|
Edited 1 time(s). Last edit at 2024-05-31 16:26 by garbuya.
#4 Re: Bug in replacing string
Posted by: pspad | Date: 2024-05-31 20:18 | IP: IP Logged
sorry, I didn't noticed, you replace with same char + \n
This is a problem for current editor component used in PSPad.
I can workaround it, but it's anoying.
First replace | with e.g. |§
As second step replace § with \n
#5 Re: Bug in replacing string
Posted by: garbuya | Date: 2024-05-31 21:11 | IP: IP Logged
Still does not work
ab|$cd|$|$|$|$ef|$|$|$ghi|$j|$
Backward replace $ by \n
Expression replaced one time
#6 Re: Bug in replacing string
Posted by: vbr | Date: 2024-06-04 13:43 | IP: IP Logged
garbuya:
It does not work
i guess, a part of the problem is the search pattern, | is a special (meta)character in regular expression mode;
You have to escape it with a backslash for searching a literal "pipe" |
The other part is indeed the current limitation of PSPad in searching/replacing newlines.
However, in this case the mentioned workaround seems to help - backward search direction, after placing the cursor at the end of the file.
Search for:
Replace with:
|\n
[x] Regular expressions
Search direction
(.) Backward
hth,
