You are here: PSPad forum > English discussion forum > Re: Reverse search (inverse search command-line).
Posted by: pspad | Date: 2024-05-03 11:23 | IP: IP Logged
Can you please provide me command what is sent to PSPad?
Is there whole file name include path with correct file extension (not PDF)?
Posted by: jcfaria | Date: 2024-05-11 16:34 | IP: IP Logged
Jan, yes it exists!
Most PDF viewers send complete information (sometimes only approximate) of the location where the user double-clicked.
This allows the reader to locate - immediately - which *.tex file of your sources the user double-clicked on.
When I worked with this (reverse search) coding in Tinn-R - it's been many years, and it still works well today - I noticed that not all viewers have this feature. I suggest Tinn-R users use Sumatra, as it is very accurate in sending information.
You can read about this in the Sumatra documentation: www.sumatrapdfreader.org
If you need, tell me and I can send you the part of the Tinn-R source code that does this. And it's good, I believe.
