You are here: PSPad forum > English discussion forum > Re: Change XHTML.DEF
Posted by: Piotr | Date: 2024-04-18 06:53 | IP: IP Logged
I change the content of the file:
Program Files (x86)\PSPad editor\Context\XHTML.DEF
After saving the file, I see my changes, but PSPad does not see these changes.
What am I doing wrong?
Thanks
Posted by: pspad | Date: 2024-04-18 10:48 | IP: IP Logged
Program setting / html multihighlighter
What is set a html multihighlighter base? HTML or XHTML?
Posted by: Piotr | Date: 2024-04-18 12:39 | IP: IP Logged
Multihighliter Base: XHTML
Posted by: pspad | Date: 2024-04-19 04:49 | IP: IP Logged
XHTML.def is for .xhtml file extension. If you need it for .html, you need to modify HTML.DEF
Template File name = extension of the file you use
Posted by: vbr | Date: 2024-04-19 18:21 | IP: IP Logged
Piotr:Hello,
I change the content of the file:Program Files (x86)\PSPad editor\Context\XHTML.DEF
Thanks
the path:
...\Program Files (x86)\PSPad editor\...
is likely a protected folder in windows, the changes are possible only with administrator rights for the editing program (otherwise the saving is "masked" and hasn't any effect).
Alternatively, a portable installation of PSPad can be moved to some not-protected folder, or a multiuser mode cam be used, where theses files are stored in an accessible user folder.
Pspad settings: Program settings: System integration
[x] Multi user environment
hth
Posted by: Piotr | Date: 2024-04-22 14:19 | IP: IP Logged
Thank you for your replies
I've changed files this way before.
It worked.
I don't know why it doesn't work now
I see the changes in Windows Explorer.
PSPad doesn't see them
Posted by: pspad | Date: 2024-04-22 14:34 | IP: IP Logged
If your file extension is .html, you need to change content of the HTML.DEF file
Or try menu File / New (Ctrl+N) and choose XHTML from template list
