You are here: PSPad forum > English discussion forum > Suggestions
Posted by: ack | Date: 2024-03-03 18:45 | IP: IP Logged
Hi, I'm missing the following functions/features:
1) In the menus I did not find any hint for increasing/decreasing Zoom;
just found out randomly that <ctrl>-Mousewheel works fine.
2) When setting readonly-mode for a file opened in PSP, it would
be useful to open in r/o-mode again when closing/starting PSP again.
3) When a file is set to r/o-mode and then typing something
it would be nice to open the search-window automatically.
4) When sorting with "Remove Duplicates" it would be useful
to have an option to be prompted for each deletion (just like in the Replace function);
further it would be useful to be notified about how many deletions
had been done.
Thx for reading.
Posted by: pspad | Date: 2024-03-03 19:26 | IP: IP Logged
1. Use Ctrl+ mouse - temporary for file or use format / Font for global permanent change
2. Program settings / Files - activate save file state or in the Program settings / Program 1 activate option R/O mode changes file attribute
3. I am not sure about it. Ctrl+E is incremental search for fast search
4. Duplicates can be in any part of file. It means such prompts will be chaotic and repeating.
