You are here: PSPad forum > English discussion forum > AutoCorr.txt does not work anymore
#1 AutoCorr.txt does not work anymore
Posted by: PaulPic | Date: 2024-02-10 01:27 | IP: IP Logged
It used to work for years, the file is still there, but it does not load - how come?
I find Spell settings being empty and would like too feed this file into it, but this does not seem the way.
Also, adding dic files is not the solution. I am confused.
#2 Re: AutoCorr.txt does not work anymore
Posted by: pspad | Date: 2024-02-10 05:58 | IP: IP Logged
Autocorrection file must be in settings folder. Open program settings / backup. On the bottom of screen you see the folder.
Autocorrect must be enabled in spell settings.
#3 Re: AutoCorr.txt does not work anymore
Posted by: PaulPic | Date: 2024-02-10 09:27 | IP: IP Logged
Thank you very much.
OK, I see the folder and the file.
It is enabled.
And it does not work except if I transfer an item from Autocorr.txt to the spell dialog manually. Autocorr.txt has 270 lines, though, so that would be a lot of work.
So again, why does Autocorr.txt no longer work?
#4 Re: AutoCorr.txt does not work anymore
Posted by: pspad | Date: 2024-02-10 10:42 | IP: IP Logged
I will check it
