You are here: PSPad forum > English discussion forum > Re: dirty char on save script
#1 dirty char on save script
Posted by: uffa14 | Date: 2023-11-09 17:02 | IP: IP Logged
hallo,
Sometimes saving script insert some bad chars into the code as in this code snippet:
Is a pspad problem or something doesn't work in my computer?
#2 Re: dirty char on save script
Posted by: pspad | Date: 2023-11-10 06:43 | IP: IP Logged
Your PSPad version?
#3 Re: dirty char on save script
Posted by: rseibel | Date: 2023-11-15 12:44 | IP: IP Logged
Never Ending Story:
When will this error ever get fixed ??
I have this error of inserting character "ÿ" in files multiple times every day!
Coding the whole day with many big files open, search (and replace) in many big directories ...
Maybe, some users need ChatGPT interface etc. etc., but without a reliable editor this is all useless for me.
I use PSpad since many years, i donated some money, i check this out with every new beta version in 32 bit, but nothing happens.
After checking 5.5.1 (790) same procedure as before sad smiley
If you don't plan to look after this error, it's ok for me, maybe there are only few (power) users with this problem.
But when there are no plans from your site, i should stop using PSpad,
not happy about that, but necessary for my development process.
Regards, Roger
#4 Re: dirty char on save script
Posted by: Freeman | Date: 2023-12-10 08:24 | IP: IP Logged
rseibel:
I confirm this in that version. Fortunately seldom than in versions before, but still suddenly appears.
#5 Re: dirty char on save script
Posted by: PaulPic | Date: 2024-02-05 11:13 | IP: IP Logged
Same problem for years, not very often, but it still happens.sad smiley
#6 Re: dirty char on save script
Posted by: pspad | Date: 2024-02-05 13:35 | IP: IP Logged
I am testing new editor component. But it will be time consuming to replace whole internal functionality
