You are here: PSPad forum > English discussion forum > Line Wizard - a new PSPad extension
#1 Line Wizard - a new PSPad extension
Posted by: shpati | Date: 2023-11-07 20:05 | IP: IP Logged
Hi all. I bring to the community a new PSPad extension.
It is called Line Wizard.
This extension contains useful commands for text modifications, such as:
Add text at the start of each line...
Add text at the end of each line...
Add a line break before a given text...
Add a line break after a given text...
Remove the first word of each line
Remove the last word of each line
Keep only the first word of each line
Keep only the last word of each line
Keep only lines containing a given text...
Remove lines containing a given text...
Remove blank lines
Remove redundant blank lines
Remove redundant spaces
Remove leading spaces
Remove trailing spaces
Remove leading and trailing spaces
Replace text between a given string (exclusive) and the end of the line...
Replace text between a given string (inclusive) and the end of the line...
Replace text between the beginning of a line and a given string (exclusive)...
Replace text between the beginning of a line and a given string (inclusive)...
Find and Replace text...
Where to download the LineWizard.vbs file:
raw.githubusercontent.com (right click on link and then Save link as...)
How to install:
Open the folder where PSPad is installed.
Copy the LineWizard.vbs file inside the Script\VBScript folder.
Restart PSPad and go to the Scripts menu where you will find the Line Wizard group of commands.
Note that script usage within PSPad must be enabled for the file to load.
Edited 1 time(s). Last edit at 2023-11-07 20:07 by shpati.
