You are here: PSPad forum > English discussion forum > GUID or UUID selection with double click
Posted by: ositnick1 | Date: 2023-10-20 20:01 | IP: IP Logged
Hi everyone,
Could you please advise how could I adjust PSPad for the selection the whole GUID/UUID value with double click?
Some programs can select whole representation of GUID with double click. For example, I can select the whole string f4f62877-016b-4797-b001-8edde1db136e with double-click in PuTTY or KiTTY as well as in GIT-Bash or Windows command shell or powershell.
Thanks for any solution
Edited 1 time(s). Last edit at 2023-10-20 20:01 by ositnick1.
Posted by: pspad | Date: 2023-10-22 14:24 | IP: IP Logged
Word break chars when you selecting text with doubleclick (e.g. "-") depend of highlighter.
If GIUD is enclosed by quotas, you can use select text inside quotes - Ctrl+DblClick
If Guid is placed inside brackets, you can use Select text inside brackets Shift+Ctrl+M
Posted by: ositnick1 | Date: 2023-11-17 09:00 | IP: IP Logged
pspad:Word break chars when you selecting text with doubleclick (e.g. "-") depend of highlighter.
Oh, I guess it would be wonderful if I could update the SQL highlighter to remove the "-" char from word delimiters. Unfortunately, I could not find how do it. Could you please give me any clue?
Thank you.
