You are here: PSPad forum > English discussion forum > Bookmarks operations
#1 Bookmarks operations
Posted by: davihog683 | Date: 2023-10-07 16:25 | IP: IP Logged
Hello. Want to move from notepadpp to pspad.
But one userfull thinks that are stoping me from moving.
Is it possible to extend operations with bookmarks? For example:
I want to mark some lines with bookmarks and then remove them, cut/copy them, remove everything except bookmarks?
#2 Re: Bookmarks operations
Posted by: pspad | Date: 2023-10-09 07:09 | IP: IP Logged
You can mark any count of lines with bookmarks.
In the Search dialog you can use search and mark lines with "Create bookmarks" button
In the menu Search (in bookmark section) is possibility to delete marked lines
You are right, copy possibility of marked lines is missing now. I will add it.
If you need it just now, you can use PSPad scripting capabilities and write simple script what will do this job for you
#3 Re: Bookmarks operations
Posted by: davihog683 | Date: 2023-10-09 16:36 | IP: IP Logged
Yes, i was going, then i spotted - scription is not supported in 64 bit version.
Would say that bookmark operation is most powerfull things for me. But anyway thanks in advance for pspad. Its UI looks very nice to me smiling smiley
#4 Re: Bookmarks operations
Posted by: pspad | Date: 2023-11-15 10:42 | IP: IP Logged
New function in the menu Search in the following build:
Copy lines with Bookmarks
Delete Lines without Bookmarks
