You are here: PSPad forum > English discussion forum > Disable font smoothing in 5.0.7
Posted by: obones | Date: 2023-09-21 11:57 | IP: IP Logged
I have just updated PSPad to 5.0.7 and to my great despair, the font in the editor is smoothed, making it barely readable to me.
The previous version (5.0.6) did not activate font smoothing in the editor, and that's the way I want it to be.
On a 96DPI monitor, font smoothing actually means that everything is blurry, adding lots of eye strain.
I could not find a way to disable this in the various options, so am sticking to 5.0.6 for the moment.
Thanks for your answers.
Posted by: pspad | Date: 2023-09-21 12:55 | IP: IP Logged
Open program settings / Direct edit button
find line UseClearType
and change value to 0:
UseClearType=0
Posted by: fanoush | Date: 2023-10-23 09:51 | IP: IP Logged
Thanks, this does work but when you then go and change font (e.g. to Courier New) it comes back.
I needed to set font directly in the config file too and then it works.
Posted by: pspad | Date: 2023-10-23 10:09 | IP: IP Logged
This should be permanent.
Posted by: fanoush | Date: 2023-10-23 10:24 | IP: IP Logged
It is not. I upgraded from 5.0.6 to 5.0.7 (64 bit) and the font changed to Consolas and cleartype got enabled, fortunately I found this topic. When changing it to 0 it really turns cleartype off but then when switching font back to Courier New cleartype is enabled again (and setting still has UseClearType=0).
After exiting pspad in this state and starting again cleartype is again off but font change was not applied and I had Consolas again. The only way to change both was to go to direct edit and change both cleartype and font directly there then exit pspad and start again.
[Special settings]
UseClearType=0
[Font]
Name=Courier New
HEXName=Courier New
LOGFontName=Courier New
Edited 1 time(s). Last edit at 2023-10-23 10:25 by fanoush.
Posted by: pspad | Date: 2023-10-23 10:52 | IP: IP Logged
I just tested. I use Fira code font. even I changed it to Consolas or Courier New, no clear type was activated.
Can you please test it with 5.5.1 (32b) from PSpad developer forum?
For test unzip it somewhere out of program files and run PSPad.exe from this folder.
PSpad will behave as portable and all settings will be stored into files in this folder.
Posted by: fanoush | Date: 2023-10-23 13:13 | IP: IP Logged
Tried latest 32bit pspad551b790 and it behaves the same. In fact this is some bug when changing font. Any font change, even just opening font dialog, keeping same font and clicking OK enables cleartype again. But fortunately this is only temporary, exiting an relaunching pspad helps. This is Windows 11 with latest updates BTW.
Anyway, since this is only temporary it doesn't matter much, I don't change fonts so often
You can see it here ibb.co - opening dialog and clicking OK. Just open the images fully as otherwise they are scaled down and font smoothing difference is not visible.
Edited 1 time(s). Last edit at 2023-10-23 13:18 by fanoush.
Posted by: pspad | Date: 2023-10-23 14:08 | IP: IP Logged
Thank you for info.
I will call clear type disabling after font change.
Posted by: pspad | Date: 2023-11-15 09:40 | IP: IP Logged
Done, available in the next build
