You are here: PSPad forum > English discussion forum > Re: versions after 5.0.6 (589) unusable on my system
Posted by: mihau | Date: 2023-09-04 12:38 | IP: IP Logged
hello,
many thanks for this immensly helpful editor. being a hobby programmer, I've been using it for 15 years or so.
as of version 5.0.7 and all the following developer versions, it is unusable on my system (windows 11). the toolbars are now pretty much invisible black on black, and also the font in the editor area is now blurry (while I'd like it to be sharp as before).
here are two screenshots of "before" (5.0.6) and after (all later versions):
I checked the options/preferences, but couldn't find anything that would correspond to the issues.
I'm suspecting at least the toolbar issue has to do with my permanent dark system UI color theme.
I've tried searching this forum, but apparently nobody had this problem before.
for now, I'm sticking with the old version, but it would be awsome if someone could point me in the right direction how to keep using new versions of this awsome editor
any ideas? hints? suggestions?
any help is appreciated
thank you,
mihau
Edited 4 time(s). Last edit at 2023-09-04 12:45 by mihau.
Posted by: pspad | Date: 2023-09-04 12:57 | IP: IP Logged
Is your PSpad installed or unpacked?
Does .\Skin subfolder exists and contains bitmaps?
Can you open settings / Program 1 and choose iconset for toolbar from the list?
Posted by: mihau | Date: 2023-09-04 15:45 | IP: IP Logged
pspad:HelloIs your PSpad installed or unpacked?
I was using a very old installation and simply unpacked the newest latest- and developer editions over it
got it, thank you so much!
fixed both the toolbar issue and found the font settings
sorry for having wasted your time
